 Removing Rolling Furler from C25 TR
x_HoldFast_x
Initially Posted - 10/17/2018 :  06:48:16  Show Profile
Hi all,
I have a Catalina 25 Tall Rig. I am prepping the boat to go on the hard for the winter and I need to remove all the sails. This is the first winter I have owned the boat. Do I need to go up the mast to remove the rolling furler? I don't have binos and cannot see how it is secured to the mast. Any special tools required to get the job done right?
x_Hold Fast_x
S/V Shamrock 5
Catalina 25
#4520
Response Posted - 10/17/2018 :  07:39:36  Show Profile
If your not lowering the mast and only want to remove the sail then unfurl the sail then unclip the sail down by the drum then uncleat the jib halyard and pull down on the sail. It will slide down and out of the groove in the RF extrusion. The swivel that the halyard is attached to will come down also. Unclip the sail from the swivel. No need to remove the RF itself. Leave the swivel in the down position and unclip the halyard from it and reclip it somewhere else like the base of a stanchion.
Edited by - islander on 10/17/2018 07:51:45
Response Posted - 10/17/2018 :  07:55:11  Show Profile
What make is your furler? If leaving the mast up, just do what Scott says. The furler foil (tube) just stays put. If taking the mast down, and the furler foil is metal (not a plastic CDI), care must be taken to keep the furler foil reasonably straight once the forestay is disconnected from the stem fitting. Since it's longer than the mast, that takes some attention until the mast pretty close to horizontal, at which point you can lash the foil to the mast at enough points to support it before you detach the mast from the step.
x_HoldFast_x
Response Posted - 10/17/2018 :  10:23:15  Show Profile
Thanks Scott and Dave. I am leaving the mast up, so I'll give it a go this weekend.
S/V Shamrock 5
Catalina 25
#4520
HappyNow
Response Posted - 10/17/2018 :  14:35:41  Show Profile
If you have a CDI furler, you need to tie a messenger line to the halyard before you pull the sail down, so next year you will be able to raise the sail without having to retrieve the halyard, which will get pulled to the top of the furler and won't be reachable.
Michael Levin
Sailin' on Sunshine
C250 #402 WK
Lake Tahoe
Response Posted - 10/17/2018 :  15:51:26  Show Profile
Id like to add that my directions are for a non CDI furler. Also try and do this on a day with none or little wind because you are unfurling the sail. Wrestling a fully inflated sail or one that is vigorously flogging, Not fun.
Response Posted - 10/17/2018 :  21:07:08  Show Profile
One more caution: When you get the sail down and remove the halyard shackle from it, be careful not to let go of the shackle until you've hooked it on something--otherwise, the weight of the halyard on the other side of the mast, depending on where it's hanging (such as in the cockpit), could pull the shackle back to the top of the mast, which could ruin your whole day (if not now, then next spring). I would attach the shackle to a stanchion base and cleat the other end of the halyard somewhere like the a jib sheet cleat so that both ends wouldn't slap on the mast all winter. Similarly, the main halyard can be shackled to a stanchion base and cleated somewhere like the bow.
x_HoldFast_x
Response Posted - 10/18/2018 :  12:46:43  Show Profile
I believe my fuller is a Hood 700SL, not a CDI. Thanks for the warning, if it was.
S/V Shamrock 5
Catalina 25
#4520
x_HoldFast_x
Response Posted - 10/23/2018 :  09:10:56  Show Profile
Thanks everyone. This was a quick job and everything went smoothly.
S/V Shamrock 5
Catalina 25
#4520
blanik
Response Posted - 10/28/2018 :  11:04:49  Show Profile
A video is worth a thousand words ;-)
https://youtu.be/hPqbFoAijGY
1984 C25 FK/SR #4593
Lake Champlain
Edited by - blanik on 10/28/2018 11:05:54
