 Which Holding Tank From Catalina Direct?
sethp001
Mainsheet C-25 Tech Editor
Initially Posted - 07/16/2018 :  17:04:58  Show Profile
Catalina Direct offers three different holding tanks for our boats. All three state that they are for traditional and dinette interiors. The one that costs $287.93 appears to be the closest in dimensional shape to the fresh water tank under the starboard settee, which I'm guessing would have the best fit under the port settee in a traditional interior. So why do they offer the others? What am I missing?
You can see all three here: https://www.catalinadirect.com/index.cfm/category/318/plumbing.cfm
Seth
"Nomad" 1980 Prindle 16
Edited by - sethp001 on 07/16/2018 22:44:05
keats
Response Posted - 07/16/2018 :  20:46:13  Show Profile
My 85 with traditional interior has the fresh water tank on the port side so, who knows? Looks like you have to carefully check the dimensions and the location of the outlets to get the right one. The CD people will be very helpful.
Tim Keating
1985 C-25 TR/FK #4940
Midsummer
Lake Don Pedro, CA
Response Posted - 07/16/2018 :  20:53:31  Show Profile
I have the dinette table interior - with two opposing bench seats with a table in between on the port side. The tank that looks the closest to mine is item # Z1987, Holding Tank C-25 Trad C-27 Dinette, C-30 C-36 for $287.93
Folks with port and starboard settees might have a different tank, but I have no direct experience on this.
Edited by - Voyager on 07/16/2018 21:00:17
Erik Cornelison
Response Posted - 07/17/2018 :  12:57:02  Show Profile
My ‘86 dinette also has z1987 holding tank.
Erik Cornelison
1986 Standard Rig SW. #5234
Response Posted - 07/17/2018 :  16:02:04  Show Profile
Oh, wait!!! Did you say port settee? There’s another one that’s a mirror image of the starboard settee tank. Look at Z1991 or E2219. They look to be the obverse of the starboard tanks. Z1991 is smaller and more likely to fit, but check the dimensions.
Edited by - Voyager on 07/18/2018 05:55:10
Response Posted - 07/18/2018 :  08:45:47  Show Profile
Route cause answer is that Catalina made both modifications over the many years our boats were manufactured and had two versions -- standard and dinette. An additional factor is that they used parts, such as tanks, in different models so a change in one model, say the 27, might cascade to a change in the 25. Whenever I have purchased parts from either Catalina yachts or Catalina Direct, I have measured and measured again to make sure I have the correct size and then let them advise if their is any confusion.
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
Response Posted - 07/18/2018 :  09:35:11  Show Profile
Guys, Don't confuse the holding tank with the fresh water tank Holding tank was placed on the port side and the fresh water on the starboard side.
From the manuals & brochures
FRESH WATER SYSTEM
The galley is supplied fresh water from a 16 gallon high density plastic tank located under the starboard settee. The tank is filled thru the vent cap mounted directly on the tank or thru the optional deck fillplate, located on the starboard side deck. The deck fill is labeled water.
HOLDING TANK
The optional holding tank is made from high density polypropylene plastic. The tank capacity is 14 U.S. Gallons. It is located under the forward end of the settee or dinette seat on the port side.
jduck00
Response Posted - 07/21/2018 :  07:13:10  Show Profile
Are you looking to replace yours? I put ~20 gallon tank in the vberth. I found that you can order pretty much any size or shape tank from stock options from online suppliers. Click on the picture and it will take you to the album that shows some of the work.
Jeremy Duck
The Lucky Duck
1980 SKSR Hull # 1850
