Finally had the time and the weather to put my new main on and go for the first sail of the season ... Until I go to put the slides in the track , they are quite large and flat and do not even fit thru the gate let alone into the track . Checked my old ones when I got home they are smaller and round . Have to send sail back now for correction . My question is do any of our boats have the mast track that accepts these bigger flat slides ? Or are they just wrong ?
Oh my! The same thing happened to me! I got my new mainsail from Catalina Direct//ullman and the slides do not fit into my mast gate.
What is even more disappointing is I have really had to work with CD to get them to believe me. Several rounds of sending pics. I even got a reply saying they ARE the correct slides. (I thought to myself, “ummm, do you wanna come over and show me how to insert them?”)
This is frustrating after waiting 6 months to receive the sail. I bought a new sail after my old one tore, so I now have no functioning mainsail. I also have a San Juans cruise scheduled in 4 weeks. After a week of emailing and calling CD, I still have no solution being offered and still have the un-usable sail at my house.
The slides are sewn on, so it isn’t as easy as just replacing them.
If you can find a dozen or so of the correct slugs, you can literally “sister” them to the current slugs. [That may be a politically incorrect term]. Just clip them to the current slugs and go sailing. Do you also have a separate line to pull down your sail? I tied a 3/16”line to the 2nd topmost slug to pull the sail down when I want to douse it.
It very disappointing for sure , buying a new sail takes some justification ( at least for me ) its a big ticket item . Plus I had it for two months before I could try it out . I dealt with Ullman out of Anacortes directly and they seemed very professional and cooperative , so I'm hoping things will work out when I contact them on Monday .
WM carries a wide selection of slides, and they aren't expensive. Any sailmaker can replace them, but CD should stand behind what they sell. I don't think any C-25 has an external track for flat slides.
Dave B. aboard Pearl 1982 TR/SK/Trad. #3399 Lake Erie/Florida Panhandle
I went thru Ullman directly ,taking advantage of the fall CD sale , so I'm more then optimistic they will sort it out . I'd rather have it professionally done if possible , being a new sail and all .
Are the problem slides shaped like thin rectangles, rather than cylinders with spherical ends? On other boat brands I've seen mast slot shaped like it was formed around a T-track, instead of around a cylinder.
I seem to remember something about Catalina changing spar extrusion suppliers awhile back, possibly during the production run of the Catalina 25. I think when looking up mast parts for a Catalina 22, there's a note about which brand of extrusion do you have?
I'm not a fan of slugs sewn on with webbing. I prefer sturdy slugs attached with metal shackles to metal grommets behind a bolt rope. I'll put up with the weight aloft, noise, and air gap in exchange for serviceability.
quote:I'm not a fan of slugs sewn on with webbing. I prefer sturdy slugs attached with metal shackles to metal grommets behind a bolt rope.
I agree, You can change a broken slug on the fly in 10 min. without having to take the sail to a shop. They will be mandatory whenever I order a new sail.
They are thin rectangles that don’t fit in the gate .
ive replaced a few slides on my uhlamn main. the white plastic ones break at the battens. takes about 20 min to replace the webbing sewn in sliders. next sail i order will have sliders held on by shackles.
I mentioned in a previous reply that I was also having difficulty with sail slides not fitting in the mast gate on my new CD/Ullman sail. By the way, it is a 2+2 batten tall rig mainsail.
In my situation, the slides are the correct round shape, with stainless steel bails and attached with sewn-on webbing. However, they are 10mm in diameter while my old ones are 9mm. Apparently the gate is about 9.4mm. I am also a bit bummed about the sewn webbing for the reasons stated by others.
CD has suggested several solutions, two of which I am considering as possible. I would value the input of this forum before deciding.
1) I use a dremel or some such tool to widen the gate to receive the existing 10mm slides. BTW, my mast is down, so I was able to test the slides in the slot by feeding them from the bottom of the mast. The 10mm slides DO fit the mast slot, just not the gate.
2) I return the sail to Ullman for slide replacement. CD and Ullman are discouraging this option, but they are willing to do it. The reason stated is that they would have to switch to smaller diameter, all plastic slides and they believe I will experience excessive breakage of slides in the full batten areas.
What do you all think? Any better ideas?
Anything I can/should do about the sewn webbing issue? Frankly, I never considered the new sail would have sewn webbing, fully assumed it would come with shackled slides. DOH!
Just widen the gate. I reshaped my gate with a file to fit my mast gates. The webbing will last a long time so until you have a problem I would just leave it.
The webbing should not be a problem. Mine has lasted fine. It's just a pain in the butt to replace broken slides. Sounds like you have better slides anyways.
When I had my new main built I got nylon slugs with the SS bail running down into the barrel, and I had them seized on with webbing. The slugs are unlikely to break at their narrow necks, with the bails providing substantial reinforcing, and the webbing tends to encourage them to stay oriented parallel to the luff instead of pivoting inside the tunnel, so they have less tendency to bind. Check out the Sailrite website for the variety of slugs and slides they provide, as well as their suggestions about how to secure them to the sail.
Lee Panza SR/SK #2134 San Francisco Bay (Brisbane, CA)
Just to follow-up on my slide situation, I filed the mast gate wider and the new (over-sized but stronger) slides fit great!
I spent about 10-15 minutes filing the side that was already widened for the gate. It was easy work. I placed a towel under the area to catch shavings, then shook it out in the trash. The gate still has plenty of material left to be strong; in fact, it doesn’t look any wider.
purchased a full batton mainsail from mack sails. It came with flat slides they said they work better. Had to use dremel tool on one side to fit into slot. They work well satisfied
Ken Chenango~ 1990~TR~WK~C25~#6022 Candlewood Lake, Ct
A "square peg in a round hole"... Doesn't sound great long-term to me. Flat slugs are meant for a flat track, which on some boats is a separate extrusion attached to the mast. I don't think I've seen a flat track on a C-25, and I seriously doubt any before about 1988 had them. Mack got it wrong--I'd make the get it right.
I'm surprised at Mack Sails whom I would consider to be a higher end sail maker. I don't understand how they couldn't have the correct slugs, They make sails, Not storm doors and I'm sure this isn't their first rodeo with a Catalina. I agree with Dave. Our slug tracks are curved. A flat slug will bridge the track putting all of the stress on the outside edges making them prone to breaking I would think. Will they work? Sure, But the real question is will they last.
...Will they work? Sure, But the real question is will they last.
And will they carve two grooves in (and maybe through) the cylindrical groove, and will they slide easily (or at all) when you're trying to douse the main in a squall. Things are designed to work with other things--but some aren't.
I also think that the barrel shaped slugs have the ability to rotate left or right depending on your tack something the flat slugs might not be able to do.
