 installing Catalina's keel bolt kit
Garboard
Initially Posted - 04/20/2018 :  20:50:08  Show Profile
Hi again...I've begun drilling to install additional keel "bolts" on my C25...I've talked about this on previous postings...I decided to go with the technique intended to be used with Catalina's kit...I've bought new black oxide and cobalt bits but the cast iron is highly resistant to drilling...I've spent several sessions trying to bore into the keel and measured repeatedly to see how much progress I'm making...BUT have only managed to drill in about 1/4"!
I'm a life-long tradesman (carpenter, machinist and mechanic) but am BAFFLED by this...
Has anyone actually installed one of these kits? INTO CAST IRON??? and could you tell me how you managed, and any technique(s) you used??
Thank you in advance!
JLR
Response Posted - 04/21/2018 :  10:10:16  Show Profile
Have you tried the pilot-hole and progressive enlarging that was discussed on your other thread? BTW, the installations so far have most likely only been in cast iron, since the later lead keels had stainless studs, nuts and washers. The rusting was only seen with the cast iron keels and the mild steel fasteners used on them. People have definitely done those installations. (I'm not one of them.)
Edited by - Stinkpotter on 04/21/2018 10:13:30
Garboard
Response Posted - 04/21/2018 :  20:20:28  Show Profile
Yes I have but with no success...I'll figure it out...eventually...
JLR
Response Posted - 04/21/2018 :  20:49:16  Show Profile
Maybe you have the illusive experimental cast carbon steel prototype keel.
Response Posted - 04/22/2018 :  05:04:16  Show Profile
I would get on the phone with someone at Catalina and separately find a boat yard that has experience replacing keel bolts -- and discuss with both. Either or both may have some suggestions and/or share techniques to best drill, as well as the rest of the various processes involved.
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
Erik Cornelison
Response Posted - 04/22/2018 :  06:52:43  Show Profile
Cast Iron doesn't work harden, so it's got to be the bit or your not pushing hard enough.
Ask this forum http://www.practicalmachinist.com/vb/cnc-machining/
Erik Cornelison
1986 Standard Rig SW. #5234
VictorS
Mexico
Response Posted - 04/28/2018 :  17:55:45  Show Profile
Please share progress pictures, thanks
Victor Salcedo
1978 C25. #453. FK. SR. L.
CTYK0453M78C
SKS
Response Posted - 04/30/2018 :  09:33:25  Show Profile
I think we talked about this before.
Catalina wasn't too particular about the quality of the cast iron used since the keel is for weight only.
You may, in fact, be trying to drill through slag instead of good metal. The slag might even be rock. Have you considered a hammer drill ?
Just a thought.
HerdOfTurtles
Response Posted - 05/10/2018 :  08:03:10  Show Profile  Visit HerdOfTurtles's Homepage
I would look into buying a slab of steel to lay down on the cabin sole and rent a magnetic drill press to put on that steel($100/day or less). Use some shims to keep it level, stand on it, have a cutting oil pump in hand and go to town.
1978 Standard Rig
Fin Keel
L-Dinette
Response Posted - 05/16/2018 :  14:55:55  Show Profile
I don’t know whether Catalina ever did this but a number of early 80s boats used ferro-cement as keels and rudders. It would be easy enough to tell. Do you get metal shavings or crappy brown sand when you drill. The stuff apparently was bulletproof!
Response Posted - 05/16/2018 :  21:27:41  Show Profile
Originally posted by Voyager
I don’t know whether Catalina ever did this but a number of early 80s boats used ferro-cement as keels and rudders...
Ferrocement was used to build hulls (and possibly rudders) as a precursor and, for a while, a poor alternative to fiberglass. It would not have provided the density to reproduce the ballast of the C-25 fin keel in the same shape and size. And I'd place a modest wager that Catalina never used it for anything. But it's an amusing theory... (Com-Pac made fat shoal keels filled with concrete.)
Edited by - Stinkpotter on 05/17/2018 07:00:15
