 150% genoa questions
avi
Initially Posted - 12/12/2017 :  22:41:57  Show Profile
Hello forum members. I have a 1988 c-25, SR, swing keel, pop top. I want to teplace the existing jib,conventioanal size that is on a roller furler, with a 150% genoa hank on style. I got the 150% genoa from a 1977 c-25 with s/r. According to the local sail shop, its $110 to convert the genoa to a furler system.
My questions are: 1. am I going to have any problems handling the 150% genoa sailig by my self? (I sail solo), and as I mentioned it is going to be on a roller furler). 2. Is there really a big advantage switching to a larger jib? ( I sail along the Texas coast). thank you.
Response Posted - 12/13/2017 :  07:02:41  Show Profile
Large sail area will help you in light to moderate winds. It will be detrimental in stronger winds, because a big sail will generate more power than you can use efficiently in strong winds, and because, in light air a big sail snags on the shrouds when you tack, but, with a furler, you can reduce it's area and thereby remedy both of those detriments.
When you tack in light air, you can roll up some of the jib and it won't snag on the shrouds. After you complete the tack, you can unroll the rest of the jib and get the benefit of the full sail area to drive the boat.
I have never sailed the Texas Gulf Coast, but, if it's anything like the Florida Gulf Coast, you'll be sailing in light air frequently in the hotter months, and you'll appreciate the bigger sail.
IMO, the answers to your questions are "(1) no" and "(2) yes."
Response Posted - 12/13/2017 :  07:22:56  Show Profile
For the 1st time in some 28 years I have to disagree with Steve (May Poseidon forgive me!). Most of the time on the central Texas ooast (Port Aransas, Rockport) the wind is pretty steady in the teens or even low 20's. Many of the racers there don't even have an O/B as the wind is consistent enough to sail in & out of the marinas. Having sailed that area many times I would not want anything bigger that a 135% and many times just a 110% (and I did all my sailing there on a 50' catamaran).
Chief Measurer C25-250 2008
San Antonio, Texas
avi
Response Posted - 12/13/2017 :  16:37:04  Show Profile
Guys, thank you for the input. I think I am going to try the bigger genoa. If its to much for me, I can always switch back to the smaller one. My understanding its not that hard to change between sails with roller furler. Maybe a little bit work, but its a learning experience.
odonnellryanc
Response Posted - 12/13/2017 :  17:28:26  Show Profile
The 150 works fine on my boat on my furler. It is very easy to handle, even in gusts if you use the purchase of the cleat on the line in a smart way.
It's a lot of fun in a run in heavy winds, but you have to be careful. Easy to pull the sail in though if you start to have problems.
I haven't sailed with a smaller sail on this boat, but my harken furler is really easy to slide the sail into. There's just a groove that the sail slides up, super simple.
Edited by - odonnellryanc on 12/13/2017 17:29:51
Response Posted - 12/13/2017 :  21:51:11  Show Profile
I'll just point out that Ryan (odonnellryanc) is less than half your age. For some of us, our opinions on burying the rail change as we "mature"...
Edited by - Stinkpotter on 12/13/2017 21:52:23
Response Posted - 12/14/2017 :  05:30:10  Show Profile
Speak for yourself Old Timer!
Response Posted - 12/14/2017 :  07:26:33  Show Profile
I said, "some of us"... I've graduated to windshield wipers to clear the white-water when I'm crashing through big chop, a hardtop over the helm, an electric windlass to haul the anchor, and a V-6 to get me outa there. Now I need some new knees...
odonnellryanc
Response Posted - 12/14/2017 :  15:40:41  Show Profile
Hey why have friends on the boat if you're not going to make them sit on the rail? :)
