 Adjustable Genoa Car Lead
DavidBuoy
Initially Posted - 08/09/2017 :  12:55:18  Show Profile
So finally got some new heavy duty low lead genoa cars to replace the ones I've been using that kind of suck. They had a lot of friction and no bearing or anything. So at this point I had 4 different types of cars that I had accumulated and decided to put them to use and create a way to adjust the cars easily on the fly.
Before I go further, yes, I know this is completely overkill on a boat this size but I already had the parts so we'll see how it works and if I like or go back to the standard setup and have them locked in the track. I figured this might be nice to share if anyone was considering something similar.
At the front I located the one I usually used for my spinnaker sheets, then the new genoa leads, then ones I got on ebay awhile back with a fairlead and cam cleat, then my old genoa cars which I will now be using for my spin sheets.
So there is a line tied to the front of the leads (which are free to slide forward and back) which goes around the block in the front, returns back to the fairlead and into the cam cleat. The pressure from the sheet will naturally push the lead back as far as it can go until reaching the end of the line. So to bring the cars back to open up the leach of the sail you ease the line in the cleat until it pushes back to the desired location. Wind starts getting light, you pull that line and it will pull the car forward and close the leach of the sail. We'll see if there's enough purchase.
Also, please mind the dirt. I'm going down there this weekend to do another thorough cleaning.
Captain Rob & Admiral Alyson
Akenumber
Response Posted - 08/09/2017 :  18:39:18  Show Profile
I think I have the same cars as your sheet cars. Have found that unlike the original cars I can adjust them loaded forward and backwards with little effort. Like the setup though.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
HerdOfTurtles
Response Posted - 08/09/2017 :  21:26:35  Show Profile  Visit HerdOfTurtles's Homepage
If it works this is fantastic for racing. For cruising it's not so good at all.
1978 Standard Rig
Fin Keel
L-Dinette
Response Posted - 08/10/2017 :  04:03:47  Show Profile
I don't think it's overkill at all, and have been trying to figure out how to rig a similar system on my Cal 25, but the Cal's track is stingier than the Catalina's. Without a system like that, if you need to adjust the car under load in strong winds, it's nearly impossible.
DavidBuoy
Response Posted - 08/10/2017 :  05:05:08  Show Profile
From Catalina Direct. Do you have a small jib that gives you a low angle to the clew? I would dare you to try to adjust my cars forward under load by hand. I think this is probably something that varies from boat to boat.
dasreboot
Response Posted - 08/10/2017 :  05:33:37  Show Profile  Visit dasreboot's Homepage
is that the car with the ball bearings in it?
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
DavidBuoy
Response Posted - 08/10/2017 :  05:36:39  Show Profile
That is correct. It's the heavier duty one.
https://www.catalinadirect.com/index.cfm/product/959_407/low-lead-genoa-car-c-25-c-250-c-27-c-270-cp-26.cfm
dasreboot
Response Posted - 08/10/2017 :  10:47:19  Show Profile  Visit dasreboot's Homepage
oh sorry, i meant this where the car has ball bearings in it. I've been thinking about it, just dont know if i want to spend $300 on it.
Todd Lewis
DavidBuoy
Response Posted - 08/10/2017 :  13:01:33  Show Profile
Oh God no. Ball bearings in the sheave but not car. I couldn't imagine spending that much money for a car.
dasreboot
Response Posted - 08/11/2017 :  04:07:51  Show Profile  Visit dasreboot's Homepage
well thats for all the pieces. if you didnt already have some, then the price would have been similar. Ive got to do something about that lead block. I can't stand the double line lead block. When I first saw it, i thought it was cool. after using it, not so much. the angle is never right. Thie sheet always rubs against the edge of the thing. Ill have to replace it eventually.
Todd Lewis
DavidBuoy
Response Posted - 08/11/2017 :  05:13:08  Show Profile
Oh, I didn't realize that is was the whole adjustable system. I thought it was just the car but with bearings against the track. Now that doesn't seem like that much money. So it can handle two sheets at once? That would be nice on a cutter rig or a larger boat, but what purpose would that serve otherwise? Avoid taking out the previous sheet when changing a headsail maybe? Definitely better if theres a single lead version.
I still haven't gotten to use my setup yet and while I know this is an extremely useful/critical thing on a larger boat especially for racing, I suspect the novelty will wear off at some point for me. Probably when I'm breaking the boat down for winter and cursing the million "extras" i've rigged.
Edited by - DavidBuoy on 08/11/2017 05:13:27
dasreboot
Response Posted - 08/11/2017 :  06:28:07  Show Profile  Visit dasreboot's Homepage
naw, this is the one that handles two sheets. Its a twin sheet lead block. I guess it is a racer thing. I cant stand them. they'd probably work a lot better if we had turning blocks rather than running the sheet directly off the lead block to the winch. then they would tilt a more efficient angle with less friction.
Here is an example of a bad block angle . the sheet is rubbing on the frame, producing a lot of friction. a regular stand up block would orient itself better. a turning block at the end of the track would make the exit for the twin sheet block more longitudinal, and it would stand up with a better entry angle. I dont think these blocks are ideal for the way our boats are set up.
Todd Lewis
Edited by - dasreboot on 08/11/2017 06:42:37
