 Sail number
C25BC
Initially Posted - 06/19/2017 :  05:56:26  Show Profile
Does anyone know if Catalina has a sight that matches sail number series with year of manufacture ? Doesn't seem to be much online .
Angus
S.V.Tempus
#4748
1984 Catalina 25 SK/SR/Trad.
DavidBuoy
Response Posted - 06/19/2017 :  07:05:06  Show Profile
Check our site's boat search and you may be able to narrow it down. Typically, unless it's been changed, the sail number matches the production number of the hull.
https://www.catalina-capri-25s.net/cgi-local/OurBoats.cgi
Captain Rob & Admiral Alyson
C25BC
Response Posted - 06/19/2017 :  07:54:57  Show Profile
I'm curious how the series number matches specific years , I know with my Cat 22 it was a 74' and 5000 series numbers (5232 ) I've read a few things on Cat 25's that may iindcate my boats a 85' instead of 84' that its registered as . Not that it makes any difference in th general scheme of things.
-Angus
Angus
S.V.Tempus
#4748
C25BC
Response Posted - 06/19/2017 :  09:53:05  Show Profile
I just went thru the registry , seems to be random , perhaps it's based on model ,type of keel , rig etc.
Angus
S.V.Tempus
#4748
Response Posted - 06/19/2017 :  10:42:21  Show Profile
There used to be two factories building C25s. One was in California and the other was in Florida. I don't know how Catalina assigned hull numbers. They might have assigned them when the order was placed by the customer, or they might have assigned them in the order the boat came off the production line, or some other system. Catalina could probably explain it, but I doubt that you could persuade the State to change the model year on the certificate of title. Government isn't usually very flexible.
C25BC
Response Posted - 06/19/2017 :  11:38:32  Show Profile
Not a big deal , just curious if there was a readily available answer . Day off , weathers miserable . After sailing all day Saturday looks like I really need to work on trimming my mainsail. It was blowing pretty good and i was not happy with how the sail looked, lots more sail adjustment on this boat need more practice I guess .
Angus
S.V.Tempus
#4748
Response Posted - 06/19/2017 :  11:54:01  Show Profile
The HIN number has all that info in it. Hull/Sail number, Year and month it was built.
Bladeswell
Response Posted - 06/19/2017 :  17:20:28  Show Profile  Visit Bladeswell's Homepage
Hello,
You can find the HIN number etched into the transon near the top on the starboard side. May not be readily visible. And as Islander said, all the info you want is contained in that number.
Bladeswell
C25BC
Response Posted - 06/19/2017 :  17:35:35  Show Profile
Yeah , that's right , I remember checking the transom when I bought it and it did end in 84 , I guess that settles any mystery there
Angus
S.V.Tempus
#4748
Response Posted - 06/19/2017 :  21:16:11  Show Profile
http://www.boatsafe.com/nauticalknowhow/hin.htm
Catalina used the first character of the serial number for the model--the C-25 was "K". So my 1985 was CTYK5032C585, meaning she was built in March of 1985 and was designated a 1985 model.
Edited by - Stinkpotter on 06/19/2017 21:27:32
TCurran
Response Posted - 06/20/2017 :  03:38:43  Show Profile
Should also have the HIN on your title and/or registration. (or at least in FL it's there)
Tom Curran
1981 Capri 25 Hull #101 "Dirty Debbie"
1988 Watkins 30
PAFB, FL
C25BC
Response Posted - 06/20/2017 :  16:34:34  Show Profile
Just looked at my seriel number last part is m841 so must be 84
Angus
S.V.Tempus
#4748
Sailynn
Response Posted - 06/20/2017 :  18:44:01  Show Profile
Just a FYI. A sail number is not required to have any correlation to a boats mfg. number in the US. I would not try to use the sail number to legally identify a sailboats year made. Sailing vessels made before 1973 US Coast Guard numbering regulations requiring a hull number inscribed on the hull, were at the discretion of the boats manufacture. The USCG regs. for boats started in 1973 had a several year grace period. Since Catalina 25 boats were mfg. after 1973 there should be a inscribed number to match the paperwork. Sometimes the boat would get painted at a later date and the number disappeared.
Lynn Buchanan
1988 C25 SR/WK #5777
Sailynn
Nevada City, CA
VictorS
Mexico
Response Posted - 06/21/2017 :  12:16:22  Show Profile
While I also fount it properly there, is it really the only location on a C25?
Originally posted by Bladeswell
Hello,
Bladeswell
Victor Salcedo
1978 C25. #453. FK. SR. L.
CTYK0453M78C
