 Replacement Sail Slide
doublereefed
Initially Posted - 06/07/2017 :  13:37:07  Show Profile
I broke a sail slide while putting in a reef. Grrrrr. Rookie mistake.
The photos aren't great, but the slide is sewn into the webbing that is then sewn to the sail. Is there a replacement product that can be installed without having to sew it in?
Thanks!
-Richard
'95 C250 WB #61
Midway, UT
Response Posted - 06/07/2017 :  14:15:54  Show Profile
Well you can hand sew a slug back on or like I have you can use stainless screw shackles. They go into the grommets you have on your sail. No sewing and if you break a slug its 10min to put another on. Sailrite has them. I think the slugs are 3/8 but measure first. Not sure about the shackle size. Here is a photo of my slugs.
frejoh
Response Posted - 06/13/2017 :  12:53:58  Show Profile
Sail Rite sells a plastic shackle which works well in conjunction with the nylon sail slug.
Fred Johnson
250 WK #669
doublereefed
Response Posted - 06/13/2017 :  13:36:00  Show Profile
You guys put me on the right path... I ended up going with this setup from Catalina Direct. I will report back on how well it works.
https://www.catalinadirect.com/index.cfm/product/70/sail-slide-stainless--shackle-set.cfm
'95 C250 WB #61
Midway, UT
