Time to replace the fixed port lights. The previous port lights were crazed and cracked, and leaked. I purchased a replacement set from Catalina Owners. They arrived in short order and the fit was very good. The instructions called for installation using just Dow 795, and the kit included 2 tubes. But at the last minute, I ran across the following video:
which makes a very good argument for using 3M (V)ery (H)igh (B)onding tape and Dow 795 as a glaze. I’m very glad I used this method. Excellent results. I ordered 2 rolls of 3M VHB Tape 5952 from Amazon, at $25 per roll. Each tape is 5 yards, enough for 2 windows.
First I had to remove old windows and remove the old sealant. The previous installation had used a number of different methods including some form of silicone, some other unknown sealant, and cheap butyl tape.
The silicone was the hardest to remove. I used a razor blade to remove most of it, followed by 220 grit wet sanding.
Following the video, I laid out the VHB tape.
Next the tricky part. As the video says: You have one chance, there are no do-overs. I practiced several times placing each window exactly. At first, I followed the video, using fingers on the sides as a guide. The results were not bad, but not perfect. Next method I tried was to place one corner, then lay the window down concentrating on the diagonal corner. This worked perfect. Once the window is in place, the tape really grabs it, with 50% of the bound within 10 minutes.
Next, glaze the windows with Dow 795. Following the video, I masked off the rim and applied Dow 795. I’m really not good at chalking as the picture shows. You need to apply just enough to fill the void, but not too much. Then you should run you finger around just once. My mistake was to play with it too long. I also laid it on too thick at one point. When I lifted the tape, it left an edge. Another mistake: at first I tried latex gloves. Just use your finger and clean with mineral spirits. One point I’m not sure of: when to remove the masking tape. I waited one hour, but I think you should remove it right after you finish glazing.
Best part of this method is that I had all 4 windows installed and glazed in less than 2 hours (not counting removal of the old set). That night we had 5 inches of rain and not a drop from the windows.
Very nice job. I love that guy's videos having seen many of them. It seems like a cleaner way than using caulk to hold the windows in place. Wow, I just saw the price for the replacement windows, $590.
Excellent article and project - thanks for doing that. I have an 84 C-25 with Aluminum frames and having issues removing the frames! Question - would you know if the older boats have the recess built into the cabin top shown on your photos? I assume my boat does not have them. I replaced the ports on my 86 C-22 which looked like yours. Thanks
I've seen it done. The lens have to be placed over the opening. There isn't an indentation for the lens to sit in. You also have to figure a way to trim out the interior.
Scott, what would you suggest for the inside trim? Starboard, teak or plasteak? The old aluminum frames would likely be corroded and detract from the look of the new portlights.
Bruce, why Starboard or Plasteak? It's inside! Go big: teak or mahogany! All it takes is a skilled cabinetmaker with experience in marine joinery... (That'll make the exterior project seem like nothing!)
Low and behold here is a photo of putting smoked plastic over the aluminum frame window holes. stang9150 posted this pic on another thread about his Bimini install but I noticed his windows had been converted so I stole his photo. Maybe he could offer up some info on the project.
