 trailer tire pressure
dalelargent
Initially Posted - 04/23/2017 :  16:10:13  Show Profile
Can you tell I am doing spring boat chores?
I am curious at what tire pressure folks run their tire tires.
I have a double axle trailer with 4 215/75D14 tires.
The only pressure marking on the tire states that max load is 1870# at 50 psi cold.
Suggestions?
1989 c25 WK/TR #5838
1998 Catalina 36 mkii
1983 Vagabond 14
Russ.Johnson
Commodore
Response Posted - 04/23/2017 :  16:29:19  Show Profile
Dale,
I have a C250WB with double axle trailer.
I think my trailer have the same tires that also have 50psi max.
I use 45psi, but I only trailer locally and not on the highway.
Russ Johnson
2005 C250WB Hull 793
WesAllen
Response Posted - 04/23/2017 :  17:37:08  Show Profile
I pull mine to Florida and back (MI) every year and my tire guys tell me to run what it says on the tires. Mine say 60 lbs. so that is what I use. No tire problems.
Wesley Allen
"Breaking Wind"
1982 C-25 SR/TR/SK #2773
Hemlock, MI
jduck00
Response Posted - 04/26/2017 :  05:59:57  Show Profile
Mine are rated at 50psi. I run 50 psi when trailering and then let the pressure off to about 35 while it sitting in the yard.
Jeremy Duck
The Lucky Duck
1980 SKSR Hull # 1850
Akenumber
Response Posted - 04/26/2017 :  19:10:31  Show Profile
You could weigh the trailer with the boat and do some math. I usually run max in trailers unless they are way over rated for their load. I have also even purposely aired them down 10 or 15 lbs on dirt or rough roads. Just watch your speed so the tires don't heat up. Air pressure is always relevant to surface area of the tire and weight.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
dalelargent
Response Posted - 04/27/2017 :  09:47:11  Show Profile
Thanks all! I do put on highway miles (I have about 75 minutes of highway driving to launch - not to mention 8 hours up to the San Juan Islands every year).
So, I think 48 psi will be my answer...
1983 Vagabond 14
Response Posted - 04/28/2017 :  17:34:31  Show Profile
Why not 50? The general recommendation is to keep the tires at their rated pressure.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
Heartbeat
Response Posted - 05/12/2017 :  12:01:00  Show Profile
Yeah, 50. Put in what it says on the tire. I know it sounds like alot, but they need it.
former Captain of Heartbeat
Catalina 25 Tall
#4816
cat25
Response Posted - 05/19/2017 :  09:18:09  Show Profile
On page 889 of the 2015-2016 west marine catalog it says single axel tires can handle 100% of their rated load. Duel axes tires must have their loads reduced by 12% below rated amount.
Ken
Chenango~
1990~TR~WK~C25~#6022
Candlewood Lake, Ct
dalelargent
Response Posted - 05/24/2017 :  23:15:43  Show Profile
Ok, sorry I haven't replied to my own thread. Too busy working and sailing. :)
I got the boat safely launched at 48psi, but will take the advice of the collective and pump them up to 50 cold for my trip to the San Juans in June (9 hours each way).
Thanks for the feedback!
1983 Vagabond 14
