Fired up the outboard earlier this winter to move from the ramp to the marina and had no indicator stream. Fortunately, opening the throttle bit produced a steady stream and I went to the marina. I ordered an impeller kit (impeller, woodruff key, and rubber connector to the indicator stream tube for $67!) since they don't stock many parts for smaller outboards in this area. Hoisting the motor off in the slip isn't difficult with an appropriate sling. But somehow, when I pivoted the motor forward to return to an upright position it tilted forward all the way to the fully up, locked position. It hits the transom before that point and I've never been able to reach that position before. Firmly against the transom, i couldn't tilt it and there was to much pressure to manually release the spring. Let me just say that hoisting a nearly horizontal motor of the mount about as much fun as jabbing a pencil into your eye. I did succeed with the help of a burly dock mate and and a half hour of struggle. Changing the impeller was as easy as advertised. The the motor was on and secured 5 minutes after reassembly, prompting my dock mate to note: "Well, that looked pretty easy."
Dave B. aboard Pearl 1982 TR/SK/Trad. #3399 Lake Erie/Florida Panhandle
Sounds like how a typical boat project goes. The teltail can get easily clogged with salt deposits or debris leading you to believe that the impeller failed. I have to clean mine a few times a season with a paper clip inserted in the hole but you can't go wrong with replacing the impeller if it's been awhile.
What Scott said. I learned the expensive way, out sailing and time to come in, started the Honda and no stream, shut it down and called for a tow as I couldn't sail into the slip. I found that if I used a paperclip sized wire to probe the small discharge hole I got the water flowing well. I now keep one handy. However it is a good idea to change the impeller during scheduled maintenance.
Mine was missing one vane and several had cracks, pretty much diagnostic. I have never had a clogged tube. I have to presume the the broken vane was pulverized by the other vanes possibly leading to their damage since there was no debris in the housing and the indicator tube is larger than the cooling pathway.
I believe that impellers die from several causes. If sand gets into the pump, it can wear down the rubber and the steel guides on either side. If the engine doesn't completely drain out fresh water and if the water freezes at the edge of the season, the ice can wreck the impeller. Any time you run the impeller dry, you destroy it. As the impeller ages, it'll disintegrate. They are made to die - planned obsolescence.
