 Winter Project Status
glivs
Response Posted - 02/22/2017 :  17:02:58  Show Profile
Bruce....have you looked into Waterlox marine finishes? It is a two part approach similar to what you are asking...apply two coats of a tung oil based sealer and then top with a diluted spar varnish. As I understand it, application is similar to teak oil, but offers a flexible topcoat similar to Cetol, and sanding from one season to the next is "optional". I have not seen it in person but seems to get good reviews and preserves the natural grain of the wood. If I were redoing my brightwork, I would consider this.
Gerry & Leslie; Malletts Bay, VT
Edited by - glivs on 02/22/2017 17:05:02
Response Posted - 02/24/2017 :  14:25:52  Show Profile
That's why I mentioned it here. The last time I sanded down to wood and finished the teak I first applied Deks Oljies oil-based finish which soaked in and looked great, then to "seal" I applied Cetol which was the tinted stuff.
I was thinking "stain then polyurethane " like I'd done around the house.
It held up well for several years.
I thought I'd do the same this time but I have the clear Cetol. I guess I could test it out both ways on the backside or on some scrap.
Response Posted - 02/26/2017 :  11:41:05  Show Profile
Gerry, no I haven't seen this before. I was looking at the original coating from last time and while it held up well, it seemed I had put it on a little too thick. Once I get all my brightwork back to clean wood I think this time I'll go with Cetol. I have a can of Cetol Marine Natural Teak that should do it. If I thin the first coat, should I do a total of three coats?
Akenumber
Response Posted - 03/12/2017 :  16:06:14  Show Profile
Huge advantage to it. Rarely have to reapply, protects and looks great for what it is.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
Sailynn
Response Posted - 03/12/2017 :  23:17:52  Show Profile
Yes you can put Cetol over oiled wood that has dried, but you can't put varnish over Cetol wood. I think I remember you can't put Cetol over Tung oil.
Lynn Buchanan
1988 C25 SR/WK #5777
Sailynn
Nevada City, CA
Response Posted - 03/13/2017 :  18:36:32  Show Profile
Yes I'm going to apply it solo. According to the literature the Cetol has a honey color and a satin finish. Should be nice.
Response Posted - 03/15/2017 :  15:59:40  Show Profile
This is 3 - 4 coats of Cetol Natural Teak:
Close hauled at 4
Close hauled at 4 knots SOG with 2/3 of the genoa, except when crashing into 3 - 4 footers
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
JamesBird
Response Posted - 03/17/2017 :  16:11:05  Show Profile
outside teak needs 3-4 coats of Cetol for it to hold up. It will last for three years without any touching up needed. Lightly sand between each coat. Inside use only needs 1-2 coats. I recommend the natural teak color as it's the lightest in color.
Jim
Danvers, MA
79 Cat25/SR/SK/(1185)
Edited by - JamesBird on 03/17/2017 16:12:52
Response Posted - 03/18/2017 :  10:33:33  Show Profile
Scuffing and single layer recoat is recommended annually. How long it holds up depends on surface wear and sunlight. I couldn't drive after hand surgery last year and face a little more work after 2 years of Ohio and Florida sun. It isn't as hard as varnish, so the frequently grabbed handrails are very worn.
edit: I don't sand between coats. I do hatch boards, trim, and rails separately and recoat at shorter intervals so I can do 3-4 coats on a section a day. The layers still bond well if I recoat when its dry to the touch and wipes town with a tackcloth without drag.. I would scuff with a Scotchbrite in between if it dried overnight.
Edited by - Dave5041 on 03/18/2017 12:44:37
