I just got a Raymarine instrument combo as part of this restoration. An i50 depth and speed with a i60 wind. I'm now wondering where would be the best place to put the thru-hull transducers. Raymarine suggests just in front of the keel which puts it in the head deck. Suggestions?
Jim Ventimiglia Toms River Yacht Club '78 Cat 25 #945 SK/SR "Pipe Dream"
You want the depth sounder to shoot reasonably vertically, so too far forward could be a problem. (The instructions probably speak to this.) I don't see a problem with it being aft of the keel, like under the quarterberth--it's not like you're going to avoid hitting something because of your depth sounder. By the time it and you detect an object, you've hit it.
I agree with Dave that having it forward won't stop you from hitting an object. I have a thru hull transducer and it is Mounted aft of the battery compartment in the quarter birth just to the starboard side of the companion way steps. There is a small hatch there. The hull is relatively flat in that area and it works very well. As a side benifit you don't have a long cable run if your display is mounted right above it on the bulkhead
I recommend you install your transducer in the same place as mine was installed by the PO. My thru-hull depth sounder transducer is installed at the aft end of the compartment under the v-berth. It works well there. The hull has little incline there. Your transducer's instructions will indicate how much incline it can tolerate. Most transducers can handle some incline, which is why they still work on heeled sailboats.
The installation manual for most depth sounder transducers I have seen indicates that the transducer should be installed forward of the keel. Depth sounder manufacturers must have a good reason for making this recommendation consistently. The purpose is not to allow time to stop the boat if the depth is shallow. The purpose is to have the transducer shooting through laminar water flow in front of the keel vs potentially turbulent flow behind the keel. Eddies and cavitation are possible on the aft edge of the keel. The air bubbles from cavitation can disrupt the transducer's signal.
Before you decide on a possible location I would find a suitable test dummy that is flat and the same diameter as the external head of the transducer. Hold it up to the hull and see if it rocks or has gaps on the port and starboard sides.This will give you a good idea of how the transducer will sit against the hull. If it does have gaps or rocks around I would find another location. The dummy puck could be cut from scrap plywood.
Mine, too, is under the v-berth. Turbulence aft of the keel can give false readings. I know that many have installed it aft of the keel and haven't noticed a problem, but why not go for optimal? Access under the v-berth is easy and the transducer is out of the way.
Dave B. aboard Pearl 1982 TR/SK/Trad. #3399 Lake Erie/Florida Panhandle
Question: Do you have a need to know your speed through the water (ignoring currents), or is your speed over the bottom sufficient? If the latter, I suggest a GPS, which tells you how fast and where you're really going, and passing on the hole in the boat.
