 Hull 922 Gooseneck Question
Carl in LA
Initially Posted - 01/16/2017 :  21:57:48  Show Profile
Hi all...
Progressing on getting the beautiful Island Dreams back online...
Raised the mast today and when getting ready to hang the boom - the crew noted that something was amiss...
Here is a pic (sorry for oversize)...
Perhaps am I missing a plastic sleeve in there that connects to the gooseneck fitting on the mast?
I have already sent an email to catalina direct asking for advice...
But does someone already know what I am up against to get this back on track?
Best to all,
Carl
Edited by - Carl in LA on 01/17/2017 07:07:14
kjk
Response Posted - 01/17/2017 :  06:58:49  Show Profile
Looks like you're missing the gooseneck clip.
Kevin J. Kiely
Rockport, MA
1999WK
Hull # 407
Carl in LA
Response Posted - 01/17/2017 :  07:09:03  Show Profile
Bummer...
Hopefully the crew at Catalina Direct can identify the part and quickly source a replacement.
kjk
Response Posted - 01/17/2017 :  07:14:30  Show Profile
http://www.catalinadirect.com/index.cfm/product/1129_631/gooseneck-clip-14-cp-22-cp-25-c-250.cfm
Kevin J. Kiely
Rockport, MA
1999WK
Hull # 407
Dave Brown
Response Posted - 01/18/2017 :  16:50:13  Show Profile
why does your goose neck look like a Gooseneck Casting C-270
part # 2019 ?
am I wrong, or is that the wrong boom ?
Dave Brown
Response Posted - 01/18/2017 :  17:00:46  Show Profile
let me correct this post.
the part you show on the boom is part # H2019.{this is for a Cat 27}
the part you need on your Boom, catalina 250,
is part # H1865 (Cat 250).
Then you,ll need part # Z2063.
hope this helps.
Davr B.
#411
Carl in LA
Response Posted - 01/19/2017 :  18:30:42  Show Profile
Davr B.
#411
Thanks Kevin and Dave...
Yes, the gooseneck is the same as they used on the 270 per the crew at Catalina Direct (for some boats during 2007)...
Here is half of the gooseneck that I was able to find on board...
Having trouble with the pic link - here is the dropbox link... https://www.dropbox.com/sc/q0ub6r9hrxo10pr/AAAzFk2vUJ2PLxr6IOP9pDyea
Edited by - Carl in LA on 01/19/2017 18:55:42
Carl in LA
Response Posted - 01/19/2017 :  18:49:46  Show Profile
So I went ahead and ordered the replacement gooseneck which was a bit pricey. At least it has several other spare parts for the boom rollers...
Carl in LA
Response Posted - 01/19/2017 :  18:52:38  Show Profile
OK - hopefully I can get my pics working from dropbox - changing the www to dl does not seem to work this evening... (it's working - copy link from different part of dropbox)
Anyway - with the half gooseneck in place and the boom zip-tied into place - I'm thinking a section of 1-inch schedule 40 PVC pipe will get the job done for the second half...
https://www.dropbox.com/s/g68mjebg7mpahav/20170118_114811%20for%20web.jpg?dl=0
Hate to be a hack but that replacement is pricey - could the pipe segment work?
(I'm not that much of a hack - I have already bought the real replacement - but if I can use a piece of pipe - why not just keep the repair kit in stock)
Edited by - Carl in LA on 01/19/2017 19:02:30
Response Posted - 01/19/2017 :  20:48:21  Show Profile
You may be one unintentional gybe away from tragedy. I'd only go with the genuine parts, and save the jury rigging for other non-structural items.
Rick S., Swarthmore, PA
PO of Take Five, 1998 Catalina 250WK #348 (relocated to Baltimore's Inner Harbor)
New owner of 2001 Catalina 34MkII #1535 Breakin' Away (at Rock Hall Landing Marina)
Response Posted - 01/20/2017 :  19:08:22  Show Profile
Your gooseneck looks totally different from the stock unit. How do you twist your boom? And where is the shackle for securing your tack?
The stock hardware looks like this. If your is different, you need to find the compatible parts:
Russ.Johnson
Commodore
Response Posted - 01/25/2017 :  22:15:24  Show Profile
Carl,
The gooseneck that Rick (Take Five) has shown is the same as my boat Hull-793 (2005).
It looks like Catalina changed the design to match the C270.
The good news is the reef clutch, outhaul clutch, and topping lift clutch look like a better design than the original.
The original Jiffy Reef system wasn't the best.
Russ Johnson
2005 C250WB Hull 793
kjk
Response Posted - 01/26/2017 :  07:28:37  Show Profile
Did they change the design? When? Or perhaps, someone switched out a boom or gooseneck from a 270 as a jury rig.I've seen some "solutions" to problems that are Whiskey Tango Foxtrot...
Kevin J. Kiely
Rockport, MA
1999WK
Hull # 407
Carl in LA
Response Posted - 01/27/2017 :  17:17:50  Show Profile
Hi All... missed a few days from checking on the post...
A week ago Catalina Direct sent the C270 gooseneck kit which had the right parts for the boom on 922...
Today made it back to the boat and installed - easy-peasy - perfect fit.
Glad that loose-end is behind me (get it)...
Carl
Carl in LA
Response Posted - 01/27/2017 :  17:21:54  Show Profile
Carl
Dave Brown
Response Posted - 01/27/2017 :  18:22:35  Show Profile
well, there ya go.
and it looks nice, and works.
glad we all sort-of-kinda helped.
Carl in LA
Response Posted - 01/27/2017 :  19:29:46  Show Profile
Thanks Dave...
... BTW - did you notice that nice new Stay-Set 1/4-inch topping lift?
Oh yeah, new running rigging to bring this lady back...
Carl
Originally posted by Dave Brown
well, there ya go.
