Is the aft bulkhead of the cabin square to the fore and aft line of the boat? I was going to install a bulkhead compass and realized that I had no way to measure this.
I'd say close enough, but it matters not--you can adjust the compass after it's installed--it probably includes the tool. Do you also have a hand-bearing compass? If so, you stand in the center of the cockpit and point it at the bow.
Maybe I'm missing something, but why does it matter? It will point north regardless of whether it is mounted or held in the hand and turned back and forth. If you want to steer on a heading 30 deg east of N, it will tell you when you are on that heading, regardless of whether the compass is mounted exactly square to the fore and aft line of the boat.
Nevertheless, having watched Norm Abrams on PBS for years, it seems to me that a fairly easy way to check whether the bulkhead is perpendicular to the boat's centerline would be to measure from the same point on the forestay to each corner of the bulkhead. If the distance is the same on both sides, then it should be perpendicular. If it's only off by a small amount, it's probably insignificant.
Maybe I'm missing something, but why does it matter? It will point north regardless of whether it is mounted or held in the hand and turned back and forth. .
its so the lubber lines actually show your heading. it's in the install instructions for any bulkhead compass. to have the lubber lines parallel to the fore and aft centerline of the vessel.
Yup. There's a line on the compass that supposedly shows your heading. The compass could read 30 degrees, and the boat could actually be pointed at 34 if the compass is mounted on something that's 4 deg. from perpendicular to the keel. But the compass can be adjusted so the card lines up correctly with the line--instructions should be included. And I'm pretty sure the bulkhead is sufficiently perpendicular. Normal leeway will produce more course error than that.
I like my hand-bearing compass method better. Yes, using the deviation magnets. That also corrects for nearby magnets or ferrous objects that might throw the compass off. When that's an issue, the adjustment needs to be made from several headings, but it shouldn't be much of an issue on a C-25 (unless you have a big speaker close to the compass).
Not to discourage the use of a bulkhead compass but in this day and age its pretty old school. GPS chartplotters or even a compass app for your smart phone are way more accurate. I have a bulkhead compass and checking it against the heading on my GPS shows that it is fairly accurate but I rarely use it for a heading over the GPS. It does serve the purpose of filling a hole in the boat
The key advantage to the GPS is it shows the heading that the boat is actually sailing, while the bulkhead compass only shows the direction it's pointed. On a beat, the two can be enough different, due to leeway and maybe a current, for the compass to cause you to not make a mark or a point you need to get around.
But any self-respecting sailor has to have a compass prominently displayed on the bulkhead or binnacle.
