 What's the best way to repair this crack?
sethp001
Mainsheet C-25 Tech Editor
Initially Posted - 09/30/2016 :  18:14:03  Show Profile
Seth
"Nomad" 1980 Prindle 16
Edited by - sethp001 on 09/30/2016 18:16:18
Response Posted - 09/30/2016 :  18:59:33  Show Profile
Tape it very closely on either side and then apply a filler.
Response Posted - 09/30/2016 :  19:53:02  Show Profile
First, where is this? Looks like the deck just inside the genoa track somewhere. At first glance, it appears to be a "spider crack" in the gelcoat--presumably the laminate beneath is solid and intact. You can verify that with a thin piece of wire. If so, I'll recommend this:
...available at West Marine and elsewhere. However, it's white--I don't recall if there are color variants anywhere. But squeeze it into the crack, let it set, and then lightly sand it flush. You might be able to add a pigment and apply it with a small tool...
If this is evidence of a bigger problem like rotten plywood core that has allowed flexing that caused the deck laminate to crack, the core problem should be solved, or nothing else will work. I won't get into that until you indicate it's an issue. It does appear, in the background of the picture, that some patching has already been done. (...the white stuff?)
Edited by - Stinkpotter on 09/30/2016 19:54:23
DanM
Response Posted - 10/18/2016 :  14:30:47  Show Profile  Visit DanM's Homepage
Thanks Dave for your advice on this product. I tried to fill various spider cracks with "whitish" epoxy filler, with unsightly results and difficulty sanding it out. None of them appeared to be structural. I was just trying to prevent damage from neglect.
DanM _/)
'85 C25 4870
Buffalo, NY-Pt.Abino, ON
www.buffalocanoeclub.com
sethp001
Response Posted - 10/31/2016 :  12:39:43  Show Profile
Here's the final result using the bigger Evercoat Fiberglass Gel Coat Patch kit. You can't tell unless you look really closely.
Seth
Edited by - sethp001 on 10/31/2016 12:40:10
Response Posted - 10/31/2016 :  13:01:14  Show Profile
Nice job Seth, I've got a few of those gel coat cracks myself I'll let you fix. I just left them, Figure they add to the boats character
Me too!
Edited by - delliottg on 10/31/2016 14:04:10
Response Posted - 10/31/2016 :  14:26:59  Show Profile
I just looked up the kit--includes colors to mix into the patch material. I hadn't seen that version.
Nice work!
sethp001
Response Posted - 11/01/2016 :  19:12:20  Show Profile
Thanks Scott and Dave!
Seth
