 Failed Swing Keel Cable
grcccw55
Initially Posted - 08/05/2016 :  11:59:46  Show Profile
If your keel raising system were to fail, does anyone have a proven way to easily raise and support keel to be able to get boat out of water for repairs? The weight of the keel is a real problem when trying to get boat out of water!
Ben
Response Posted - 08/05/2016 :  12:23:02  Show Profile
http://www.uline.com/Product/Detail/H-2464/Dock-Equipment/Ratchet-Tie-Downs-U-Hook-2-x-15-5000-lb-Capacity?pricode=WY575&gadtype=pla&id=H-2464&gclid=CNainvD-qs4CFYQAaQodEUkOtg&gclsrc=aw.ds
I think I read a possible way to do this is to get a long ratcheting trailer tie-down, (like the one in the link above) and starting from the bow, bring it under neath the boat like a giant jump rope. When you get to the swing keel, tighten it up, and slowly ratchet the swing keel back up. It might make sense to have a person with a swim mask under the boat (not under the keel), to make sure the strap is in a good position as the keel gets ratcheted up. I have never tried this before myself, but I think I read someone else from this forum make the suggestion. Be careful though, and best of luck with whatever solution you decide on.
Ben
Beneteau 361
Viking Kitty
Columbus, Ohio
Response Posted - 08/05/2016 :  19:39:48  Show Profile
It would probably take 2 stages - a loop led aft to pull the keel as far aft (and less vertical) then another loop to winch it up. Another approach is to get the trailer deep enough so that winching the boat on will force the keel up enough to strap and winch it. Access to a lift out is the best solution.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
Response Posted - 08/06/2016 :  08:53:19  Show Profile
Then there's the hire a scuba diver (if available) routine - replacing the cable with the boat in the water.
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Edited by - OJ on 08/06/2016 08:54:40
Response Posted - 08/06/2016 :  15:46:45  Show Profile
By far, THE most important thing you do not want to happen is to try and raise the keel with a strap and have it slip releasing a partially raised, free-dropping keel. The fall would break the keel trunk and likely sink the boat.
DavidP
Response Posted - 08/06/2016 :  19:58:17  Show Profile
This is so-o-o-o scary to me. I can't imagine why there's no backup cable or safety mechanism... !?!?!
Edited by - Voyager on 08/06/2016 19:59:51
jduck00
Response Posted - 08/07/2016 :  07:53:07  Show Profile
If you can get the trailer deep enough you can float the boat on the trailer. Its difficult, but I've been there before with a failed winch clutch. I could get mine up a little but it was mostly down. Used the trailer winch to drag the boat towards the trailer and then very slowly pulled the boat out. The boat settled on the bunks with the keel on the trailer. Took a couple of times to get it right. Having a diver attach a new cable would definitely be easier.
I wouldn't go with the strap idea for the same reasons above. If it free falls, it will be a bad day. Mine free fell after hitting rocks last year, and I ended up with a 6 week repair job. The glass stop on the keel trunk is only about 3/8" thick and doesn't do much against that much weight in free fall.
Jeremy Duck
The Lucky Duck
1980 SKSR Hull # 1850
Response Posted - 08/07/2016 :  18:55:50  Show Profile
When we bought our C-25 and hauled it out for a bottom job, we used a fin keel trailer, but didn't know that I had not raised the swing keel enough to clear the back of the trailer. We got the boat out, but it took extra effort on the trailer winch to pull the boat all the way up to the bow stop. It is doable.
DavidP
Sailynn
Response Posted - 08/07/2016 :  19:18:01  Show Profile
As stated above if you use a sideways rope or strap with the correct lifting rate, it should be secured with a second line to keep it from slipping off when the keel starts raising. I've done this on my C22 but not a C25. Now that we are much older, I would opt for a diver if possible.
Lynn Buchanan
1988 C25 SR/WK #5777
Sailynn
Nevada City, CA
Response Posted - 08/08/2016 :  10:11:21  Show Profile
Big difference in C22 and C25 keel weights, 550 vs 1,500 lbs. Stay safe, hire a diver!
DavidP
grcccw55
Response Posted - 08/08/2016 :  17:42:42  Show Profile
Thanks for all of the advice guys and gals. Think I will go with the diver first and move on from there. I didn't think about the strap breaking, and I know that would be devastating. Don't want to add to the problems I already have!
Sam001
Vice Commodore
Response Posted - 08/10/2016 :  07:49:00  Show Profile
Good luck and be safe!
Capt Sam, USCG Master Near Coastal
Isle of Hope, GA. Charleston,SC. Lake Murray, SC.
Aboard Bobbin - 1982 Standard Rig-Swing Keel #2963 Dinette Model
"On a powerboat you are going somewhere....On a Sailboat you are Already There!" Capt Sam
http://my.boatus.com//memberPhotos/6315398_1_25502.jpg
Response Posted - 08/10/2016 :  08:29:58  Show Profile
I don't know if I would trust a diver who is not a mechanic and probably knows nothing about the lifting system of your boat..Throw in the less than perfect conditions that he would be working in like visibility,current or just dropping a part. Id take it to a marina and have it hauled. Shouldn't be a problem with the keel down if they accommodate full keel boats. Easy replacement when the boats in the slings. The cost of a diver and a short haul might be about the same.
Edited by - islander on 08/10/2016 08:36:09
offshoreaccount
Response Posted - 08/10/2016 :  16:49:58  Show Profile
Trick is to dive it yourself I guess.
Offshore Account, 1977 Hull #243. SR, SK
