 torque value C25 fin keel?
rbpc25
Initially Posted - 07/16/2016 :  18:14:03  Show Profile
hi all
looking for the correct torque value for the C25 fin keel
I am seeing a slight amount of water coming in around the front bolt head and the next one aft, portside
pretty sure I have encapsulated lead and SS bolts
want to try retorquing before I grind and re-encapsulate or, god forbid, drop the keel
have not been able to find values via cursory Googling
thanks!
Rolf in MA
Rolf in MA
C25 #4959
SKS
Response Posted - 07/17/2016 :  07:39:55  Show Profile
I found this, but it pertains to the Catalina 22.
I imagine the torque value of about 15 ft lbs is the same. It would pertain to the nut and bolt, not the keel.
A larger keel wouldn't properly secure with higher torque, it would secure with more bolts.
http://forums.sailboatowners.com/index.php?threads/keel-bolt-torque.93187/
Response Posted - 07/17/2016 :  08:46:35  Show Profile
Agreed--there's probably an important limit on the torque applied with a fiberglass shell over a wood core. It's not like an engine block.
I suspect I would attend to whatever external leak(s) I could find in the encapsulation, maybe with 5200 for some resiliency as well as adhesion, before snugging the bolts. IF you're in a yard with a professional fiberglass guy, you might want to ask for an inspection and recommendations. From here, I can't see it well enough and probably don't know enough...
rbpc25
Response Posted - 07/17/2016 :  19:40:43  Show Profile
I only found numbers for the C34, but they were: 35lbs initial torque for 5200 to 'set'; then re-torque to 105lbs - there was a similar procedure on my Beneteau 235 - I don't see the sense of retorquing - the bond between bolt and washer and bore will be broken by re-tightening - they should pick an initial value and stick with it - but none of this helps my poor little C25
Rolf in MA
C25 #4959
Response Posted - 07/18/2016 :  13:43:53  Show Profile
Re-torquing the nut won't turn the stud (bolt) or break the seal around it and between the keel and the stub. They just want to compress the 5200 like a gasket. But I suspect the C-34 has a different structure and material in the keel stub.
rbpc25
Response Posted - 07/18/2016 :  19:56:18  Show Profile
Dave, you are right, of course - on my Beneteau, they are bolts, not studs (keel is drilled and tapped) - so when you re-torque on the Benny, it breaks all those nice watertight bonds and turns the 5200 into strings - on the C25, with studs and nuts, of course re-torque-ing would just squish the adhesive tighter - they both specify similar protocols, but only the stud-nut approach makes sense - score one for Catalina
Rolf in MA
C25 #4959
