Looking for any ideas for mast support to allow a cover to be placed over the mast and allow working space and protection while working on the deck. Any ideas would be greatly appreciated. Beginning long overdue work on this 1980 Catalina s/sk. Thanks
Where do you want to be protected, and what do you want to be protected from? Will you be working in the cockpit or on the foredeck? Do you just want shade from the sun, or do you want to keep rain off your work area?
If you only want shade, you can drape a tarp over the boom to shade the area aft of the mast. If you want to shade the foredeck, and, if your mast has a padeye for a spinnaker or whisker pole, then you can rig one end of a 2X4 to the padeye, and lash the other end to the forestay, and then drape a tarp over it. You can use a long pole, such as a telescoping paint roller pole, to hold the tarp's sides out, so you can have air circulation under the tarp. You could do the same to hold out the tarp over the boom.
edit: Ah, I misunderstood. You want to take down the mast and elevate it on some kind of supports, and then cover it. You could build an A-frame to support it at the stern and a similar device at the bow, but I think you might consider leaving the mast up, and rigging covers as I suggested above.
I built a frame out of PVC pipe and used a silver tarp from Tractor Supply to work under. Boat was on trailer at home which is in a heavily wooded area that helped with protection from wind. It worked OK and lasted the two months I needed to get the work done.
1988 WK/SR w/inboard diesel Joe Pool Lake Hobie 18 Lake Worth
A word of caution: the first winter we had our boat we tarped it like you are looking to do. The snow piled on the tarp and bent the mast until it rested on the cabin top. It didn't take much snow to cause this. The mast had a pretty good permanent bend in it next spring. I was able to flip it over and use a big ratchet strap to reverse the bend. I was surprised how little weight was needed to deflect the mast when only supported on the ends. Now we use a pvc pipe frame.
Chris Sacandaga Lake, NY 1984 C25 SRSK "Les's Moor"
Whatever you do watch out for birds wanting to nest in your mast. I had a pair of starlings move into my mast when it was laid up and finally the only way I could get the nest out and rewire the mast was by putting a leaf blower on one side of the mast and blowing it out. It still took some air pressure!
Yes, definitely cover the open foot. i have 2 2x4's spaced screwed together to fit the tabernacle. I actually have 2 of them, one for supporting during transport with the mast on the fore and aft pulpits and a longer one for working underneath. I have had no problems with snow induced bend using the tabernacle support
Dave B. aboard Pearl 1982 TR/SK/Trad. #3399 Lake Erie/Florida Panhandle
