We are trying to rebuild the swing keel on our boat and the cast iron is so deteriorated that we can not get accurate measurements for the thickness of the keel at the pin. Does anyone have a 25 Catalina (1980) and happens to know the original dimension at the pin or how thick is the keel at the point where the pin goes through.
The bronze pin is 1" in diameter. The keel is roughly 2.5" in width in that area, but I believe there is some variance in that. My boat is a 1980 model as well. Have you checked out Catalina Direct yet? Take look at his page. http://www.catalinadirect.com/index.cfm/category/107/pivot-assy.cfm
Are trying to rebuild the pivot assembly or looking for a new keel?
John the bushing works great, but the install is a tough job. I would say most people are like me and dropping the keel and getting it to a machine shop isn't practical. Getting the hole for it straight is the biggest challenge. I wanted a tight fit so I went a 32nd small on the drill bit and used a reamer to expand the hole. It was a long process, but I ended up with a pressed fit. I was a few degrees off perpendicular, but was able to wiggle the keel on the hangers to get it straight.
I posted my repair a few years ago. I drilled a snug, sliding fit and filled with a very high strength, maybe around 30-40 thousand psi compression, epoxy to bed the sleeve. It has held up for a few years now with no problems so far.. The hole in mine was only modestly enlarged and not elongated, so drilling straight wasn't an issue. I would look into the cost of fabricating one from 1" or 2" stainless or bronze if the keel is really bad , add spacers at the pivot and bolt lead plate at the bottom to get to 1500#. Probably not legal for racing, but it would improve cruising performance and take care of the corrosion issue. Of course, it would probably be cheaper to start with a different boat.
Dave B. aboard Pearl 1982 TR/SK/Trad. #3399 Lake Erie/Florida Panhandle
I had a swinger a few years ago that had an enlarged pivot pin hole.the bigger replacement sleeve was not big enough so I found a shop that made a sleeve out of stainless steel that would fill the enlarged hole much better and I filed out some areas and epoxied the sleeve in place. I used the boat a couple of years after that with no problem . The shop Only charged me $40.00 It is not that hard to lower the keel and try this idea .
