 What is it?
solvasoncc
Initially Posted - 11/23/2015 :  15:24:10  Show Profile
Found this on the 2000 WK boat I just purchased. Behind an after-market in-hull transducer is a solid, black, flexible, slightly tacky substance, much like a partially cured sealant. It runs from the transducer underneath the water tank, nearly all the way back to the compression post. Any thoughts on what it could be?
Below the V-Berth:
http://1drv.ms/1PKPcBy
Under the water-tank in the V-berth:
http://1drv.ms/1PKPfxd
Also, for the life of me I cannot figure out how to get a pic from onedrive to post consistently. I have tried multiple ways, sometimes it works, then I check back a day later and it is no longer working. Anyone else experience this behavior?
Charles
Catalina 250 WK SR Hull #475
College Station, TX
Ben - FL
Response Posted - 11/23/2015 :  16:03:04  Show Profile  Visit Ben - FL's Homepage
Must be what they seated the transducer in and it ran before it set up. I have my transducer set in silicone under the water tank in the forward locker. It does not penetrate the hull.
Safe voyages,
Ben
sloop Chick-a-pea,
C250wk#364
Response Posted - 11/23/2015 :  18:26:36  Show Profile
Regarding your tech issue with OneDrive, I use Photobucket instead. It has been completely reliable. Photobucket app for smartphones makes uploading from your phone's camera very easy.
Rick S., Swarthmore, PA
PO of Take Five, 1998 Catalina 250WK #348 (relocated to Baltimore's Inner Harbor)
New owner of 2001 Catalina 34MkII #1535 Breakin' Away (at Rock Hall Landing Marina)
solvasoncc
Response Posted - 11/25/2015 :  09:22:34  Show Profile
I have used photobucket in the past, but I find onedrive more convenient. I just haven't figured out how to reliably get it to post in line in a post. It always comes out too big.
Charles
College Station, TX
Response Posted - 11/25/2015 :  09:41:48  Show Profile
I have used Snapfish and Shutterfly, and both have worked well for me.
Response Posted - 11/25/2015 :  14:05:48  Show Profile
No option for what size you want? I use Flickr, Every photo has the option for small, med, large and thumbnail. For this site I usually use the medium so you don't need a wide screen to view it.
Admin
Forum Admin
Response Posted - 12/07/2015 :  13:15:08  Show Profile  Visit Admin's Homepage
But as a member you can upload your pics to the Associations Members area!
Just sayin!
