Hi all, Well the boat's coming out this week. Am taking the mast down for electrical check and also the sheaves.
One thing i'd like to add is a flag or... halyard to the spreader. I'm thinking of an eyestrap with a 22mm micro block. My worry is whether the spreader will be ok with the two holes drilled it it. I don't want to compromise the spreader just for a convenience.
Any thoughts? Jay
Jay South County RI Cat 25 SR/FK/Trad #5645 Wind Dancer
Mine has that setup. Po installed it years ago, and no problems. I do try to use marlube on all hardware though since I had mast head corosion problems in the past.
How about wrapping a piece of black plastic or rubber around the spreader and then attaching an eye-strap with two little hose clamps--all on top of the wrapper? No holes, no galvanic corrosion. (Black for better UV resistance.)
I have a flag halyard setup but it was from the PO and I do not recall exactly how it is attached. I will have to check. But the issue I have is that when I raise a flag, it sometimes gets wrapped around the adjacent stay unless the flag is not raised that high. If the flag was a smaller dimension there would be no problem but the flags generally come in the same size...forget what that size is whether it is 18" or 12". In any case, a smaller flag would resolve the issue. I rarely put up a flag and so have not given this any recent thought...until your posting.
I have the 2 pad eyes screwed to the spreaders about 1/2 way out. A small block hangs from them. I didn't put them on, The PO did. I have yet to fly a flag on them but Larry brings up a good point that if they are placed too far out the flag could get wrapped on a stay wire. Dave also has a good idea if you want to avoid drilling holes but the screw holes are so small I doubt they do anything to weaken the spreader. It has 1/8" braided line like this.http://www.westmarine.com/buy/new-england-ropes--1-8-braided-polyester-cord--P002_071_001_516
I simply lashed a CHEAP block to the spreader with some cording. No holes, no corrosion, etc. Also tied a small (identical) block to the spare hole in the chain plate below it. 4 years later there has been no maintenance, no issues, no worries, little expense and always works great.
I tied up a burgee halyard on a small block to the back stay using an "icicle hitch". It's not in Ashley's Book of Knots but I've found it on several animated websites.
I did the exact same thing with an icicle hitch... it has worked great
