My wife and I just bought a catalina 25 and we noticed that it has significant lee helm when sailing. we were wondering if this was common with catalina 25s. We would like the boat to have a slight weather helm and would like suggestions on how to make adjustments to the boat, if that is the source of the problem. My wife is the sailing expert and said on most boats if you let the tiller go it will turn in to the wind. The boat did have some work done to it before we bought it. I know 25s have an unbalanced rudder. so potentially this was not replaced and is the source of the problem? Any info would be great.
To correct lee helm, tilt the mast aft. That requires you to unscrew the turnbuckle on the forestay, adjust the turnbuckle on the backstay a little tighter to take up the resultant slack, and adjust the upper and lower shrouds accordingly.
Corresponding to Steve's advice, I found that setting my mast rake so that the main halyard hung I think about 4-5" aft of the mast at the boom gave me the ideal light weather helm in "normal" conditions. Of course things change somewhat in "abnormal" conditions--generally toward more weather helm. Using the halyard (sometimes attaching something heavy helps), what is the fore-aft rake on your mast?
The rudder isn't the issue--a balanced rudder reduces the effort to correct for weather or lee helm, but it doesn't create or eliminate weather helm--just as power steering in a car doesn't solve an alignment problem.
Almost always learn something valuable when I log into this forum. In this case, the information about trimming for lee and weather helm is especially helpful.
Thanks to Steve and Dave for the input.
Sailor Jerry C-25 "Sea Song" 1978, SK, Std. Pepin, WI
