 rust on fiberglass
bradminda
Initially Posted - 03/12/2015 :  19:24:11  Show Profile
while working on my bright work I placed 2 razor blades on the nonskid next to my winch and yes forgot them for a week. needless to say the dew caused them to rust and leave 2 perfect impressions of the blades in the gel coat. The stains are in the nonskid so sanding isn't an option any ideas. I really don't want to paint as the area isn't painted now. Baking soda doesn't work goof off either.
Response Posted - 03/12/2015 :  19:33:41  Show Profile
I suggest you forget about it and go sailing. It will probably fade away completely after weathering for a year or two. If you insist on trying to remove it, you'll probably damage the gelcoat to some extent. Looking at it every time you sail for the next two years will improve your memory.
JanS48
Response Posted - 03/12/2015 :  21:19:18  Show Profile
Greetings
Try some Commet cleanser with a brush - it will take a while scrubbing but it should get it out. Afterwards it will leave the gelcoat a bit dull, you can use one of the WM anti-oxidant cleaners to restore it like new.
Good Luck
82 C25 FK STD Rig
82 C25 SR FK
Sailing out of Newport Harbor.
Response Posted - 03/13/2015 :  05:40:14  Show Profile
If your man enough Muriatic acid soaked on a paper towel. Let it sit on the stain for 15min and stain will be gone.This works on my pool fiberglass. I've heard that putting salt on it and covering the salt with lemon juice soaked in a paper towel works but you have to leave it for 24hrs.I haven't tried that one. Do not use anything containing bleach it will make it worse.
Edited by - islander on 03/13/2015 06:16:25
Tomas Kruska
Czech Republic
Response Posted - 03/13/2015 :  08:17:33  Show Profile  Visit Tomas Kruska's Homepage
Oxalic acid is the best.
Dalpol Phobos 21, 2013, Sole Mio, hull #27, current adventures - We sail Phobos 21
PO of Catalina C25, 1978, High Anxiety, hull #701, SR, FK, L-dinette, inboard diesel Volvo Penta MD2010C w/saildrive - more info
Response Posted - 03/13/2015 :  09:14:24  Show Profile
Tomas your right, I must have had a senior moment when I said Muriatic acid. Barkeepers friend found in any supermarket contains Oxalic acid.
Edited by - islander on 03/13/2015 11:11:44
csmcg
Response Posted - 03/13/2015 :  11:15:27  Show Profile
I had success with removal of a smallish rust stain on my 250 with a Mr. Clean Magic Eraser.
Regards
Response Posted - 03/13/2015 :  17:38:47  Show Profile
And if you can't get it all off with any of the above chemicals - as Steve Milby mentions above - the sun will eventually bleach it white again . . .
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 03/13/2015 :  21:07:42  Show Profile
Soft scrub and a nylon Brillo pad?
DavidP
Poky
Response Posted - 03/15/2015 :  18:26:50  Show Profile
Try Whink Rust Remover. $4, 2 minutes, problem solved!
http://www.whink.com/index.cfm?fuseaction=cEcommerce.Product&ProductID=4328&CategoryID=1535
Paul Pimentel
85 C25TR FK #4926
Bayview, Idaho
509-475-4479 cell/text
PZell
Response Posted - 03/16/2015 :  08:28:53  Show Profile
Have had rust stains on non-skid before. Found that Clorox clean-up w/bleach squirted on helped. Used a pocket knife to scrub in between the bumps of the non-skid. Tedious but worked. Stainless steel wire brush might help too. It is after all the non-skid part of deck so no need to be polished.
Paul C25FK Sparky
'PZ' W7JVY KFS/KTK/KLB/KOK/WNU/KPH/WCC/VAI/VAJ
Akenumber
Response Posted - 03/17/2015 :  18:22:41  Show Profile
For me Barkeepers Friend worked well. I was also reading the instructions for spotless stainless and they said it would remove rust stains. It worked great on the stainless and realy good on rust stains in gel coat. I think it is high in citric acid as the active ingredient.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
