I have a persistent leak somewhere so that water enters the battery compartment (2003 C250 WK). I checked the attachments of rudder and motor mount. They are tight. I cannot see behind the waste holding tank, could there be a problem in that area? Or elsewhere... Any suggestions?
Do you have stereo speakers installed back there somewhere? That could be a source.
If you have steering, you need to go below and look out on a sunny day. Any pinhole leaks in the boot will show up as bright specs of light. That boot is prone to wear, especially around the corners. It's a $50 replacement directly from Edson.
Mine leaks in that location too. At some point a previous owner had placed a loose rubber gasket to hold pulpit mounted outboard control rods. Some water always manages to make its way into the battery compartment. I just thought the leak was normal!
I fixed a similar leak last winter which was caused by water getting into the coaming boxes. There was a seam along the cockpit-box joint which would allow water intrusion behind the rear bulkhead.
I also ended up making a new bulkhead and replacing that along with adding a battery charger, heater and battery monitor due to rot.
My suggestion would be to check that first. If you catch it soon enough it is a very easy thing to fix. Otherwise, you may be making a new bulkhead as well.
A little silicon, resin, or marine-tex should do the job. I used silicon.
On JD, I have noticed that the sealant behind the swim ladder, the fuel locker rails and the rudder mounts is deteriorating (not surprising here in South Florida). No signs of leaks yet, but my plan is to take the stainless steel off the stern this winter (cooler to be crawling around the trunk) and rebed them with Butyl.
Several years ago, a mod to deal with this was offered. If I recall correctly, the owner who offered it had a c/b so things might be slightly different for the w/k. At the ridge where the water collects just forward of the battery box, he drilled a few small holes forward into the ridge so as to drain into the bilge. DON'T DRILL DOWN
The effort stopped water from building up and coming over the ridge into the aft berth.
I can't recall if I performed the mod or not but the owner who offered it was a competent sailor and very much knew what he was doing with a sailboat. He agressively sailed his 250 a couple of years and then moved up to a much larger Catalina.
The person that wrote up the fix on drilling the holes was Oscar of Lady Kay. You drilled two 1/4 inch holes on a shallow angle from the battery compartment forward into the bilge. I don't remember the exact angle nor if one was even mentioned, but it does solve the problem of the wet aft berth. The cause was, as mentioned, the combing boxes on the 2003 and 2004 250's. For some reason they were not sealed along the bottom, just welded to the cockpit on the top and sides at the factory. You were correct about Oscars' sailing ability, he was one fine accomplished sailor.
I know this thread has been discussed several times. I occasionally get water in my aft battery compartment, which at times leaks over the lip into my aft berth. We are in the process of figuring out where the leak(s) is coming from, but also wanted to do the drill/ drain fix to get the water to drain from the battery compartment into the bilge. My questions:
1) How much space is there between the base of the battery compartment and the bottom hull... I know the suggestion is to drill at an angle, but would like to know how much leeway I have when drilling.
2) my first attempt I drilled right under the compartment opening (at an angle from the inside of the compartment drilling forward) and hit wood... I am guessing the bulkhead between the aft berth and battery compartment.
3) I cannot find the string that had the diagram... could anyone point me in the right direction?
Of course I am hesitant to drill not knowing exactly where, and exactly the right angle. Any and all help will be appreciated!
I see ads on TV for supposedly miracle sealant sprays, where they make boats from screen doors and such. The stuff now comes in white, too. Could that stop the leak if applied to the inside of the coaming box?
Why do you assume that the leak is in the coaming box? I'd do some dye tests first to confirm, before resorting to such drastic measures. You might find your spray-on goo looking pretty ugly after a couple years of UV exposure.
