It's time to plug some leaks. I have a problem in the winter in the v-berth with the underside of my cushions getting wet. It looks like I have a notable amount of water seeping in from the bow. At the extreme bow end of my v berth there is a bulkhead with a little hatch. The water seems to be coming in through the base of that bulkhead. I popped the hatch off. There I see what looks like the end end of the inner hull and ahead of it the outer hull. Water seems to be getting in between these and then into the inner hull.
All of this is underneath the anchor locker. I had a look in there. The spout for water to leave the anchor locker is at the bow end. The water escape hole is not at the very base of the compartment though so there is a pool of water, maybe 1/2 an inch deep at the bow end that probably just sits there all the time. Perhaps this is slowly seeping down into the inner hull and then through the forward hatch and into the v berth.
Any tips on fixing this. Seeems to me a good start is to get that water to drain completely from the anchor locker. Can I also make the whole thing more water-tight?
Here is the inside of the v berth looking forward with the hatch removed. (Photos should now work.)
A closer look. You can see the white of the inner hull ending as it goes forward. Ahead, that blackness seems o be the outer hull.
Inside that hatch opening, looking down. What a mess.
Now the outside of the boat. In the anchor locker, looking forward. Note the pool of nasty black water siting there with the drain hole just above it.
David Hopkins Vancouver, British Columbia '78 Swing Keel, Standard Rig, Dinette #534
David, you would do better using your membership account to post your pics. Sadly none of them are showing broken images, whereas images uploaded to the Association site are kept even when your flikr account is obsolete.
Hi David - It looks like you may need to re-glass the interior of the anchor locker. Mine actually has a loop that goes up to the foredeck. I built a chiminey from a pipe flange and a rubber furnco fitting to seal it off. Yours appears to be a much easier fix. I also tilt my bow down to be sure any water runs out the drain. Up here it doesn't mean much as the water freezes anyway.
From the photo it appears the drain is clogged. I had an identical problem in my anchor locker last year with several inches of standing water. Ran a wire through the drain and haven't had water inside the cabin since. Obviously it doesn't correct any leaks in the locker (I haven't reglassed), but the water doesn't accumulate enough to leak into the v-berth anymore.
My anchor locker leaked when I got the boat. I cleaned it really well and added several layers of glass then painted with truck bed liner. Put something in the drain that you can remove when finished when doing this. Also, I have to keep the drain clear. I do it with a piece of clothes hanger wire. Bugs get in it.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> then painted with truck bed liner.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Surprised to see someone else discovered this. I used truck bed liner to completely waterproof a floor locker in an older boat I once owned. Bullet proof. I always thought to recommend it to guys here that wanted to seal up the bilges and keel bolts that were not stainless.
<< I cleaned it really well and added several layers of glass then painted with truck bed liner. >>
Sounds like a fun project before it gets too hot outside.
Sand it down some. Wash it out good with water and then wipe it down with acetone. Plug the drain hole from the inside with a well oiled wooden plug. Pour and spread a layer of gluvit. Let it kick.
Pour and spread out a layer of resin. Lay down a layer of fiberglass matt ( probably in strips )and roll it out to saturate with resin. I'm afraid if I let the matt strips come up on the liner sides it would eventually pop off leaving a nasty edge, so I think I'd just leave the matt on the level bottom, up to the edges, and not come up the sides. Wait for it to kick.
Paint again all over with another layer of resin ( tint the resin white ), especially the edges of the matt. Let that kick.
Maybe another layer of Gluvit.
Pull the plug out. ( or check it between each step )
I havn't done a glass job in a while. ( well.. except for a gluvit job. ) .. I'd be tempted to put a poly deck paint over the whole job. ( topsides polyurethane paint )
Before I took my boat out of the water for a refit I hadn't looked in the v berth for a while. When I did there were about 10 buckets of water in there - it was salty, so not from raining in. It turned out to be the eye bolt which had only been used to launch the boat 18 months before. It was loose and although above the water line, I guess it was allowing water in every time we sailed. I dried out the teak v shaped block and sealed it with Sikaflex 291. Problem solved! Sailorbaz
I had a similar problem with my 1982 C25. A friend of mine brought a mechanics camera over and I ran water over the top while he found the leak. It turned out to be leaking around the outside of the anchor locker brass drain tube. I found a wooden dowel that fit closely in the tube and used JB weld around the anchor locker end of the tube while moving the dowel as it set up. It hasn't leaked in a couple of years now.
