 Hull Number
sailboat
Initially Posted - 04/01/2013 :  09:33:42  Show Profile
The data plate on what I think is our 1980 SK/SR Cat-25 is missing and I haven't found any data on the stern. What I did find this weekend while cleaning out the dumpster were two Catalina 25 sail bags with the number 2230 stenciled on them. Would that be the hull number and if so what information does it reveal?
Mike
1980 (I think) Cat 25 SR/SK dinette interior
S/V Chariots of Fire
Mike
Chariots of Fire
1981 Cat-25. sail number 2230
SR/SK Dinette Version
Response Posted - 04/01/2013 :  09:40:51  Show Profile
The HIN (hull identification number) should be on the starboard side of the transom, just under the rub-rail.
Other than registration, is there much more needed to know? (well except for hull no. 1)
sailboat
Response Posted - 04/01/2013 :  09:49:32  Show Profile
I will look again under the stbd (stern) rub rail. Thanks.
Response Posted - 04/01/2013 :  10:07:42  Show Profile
It might look like it was scratched in with a hot nail--mine did.
The Hull Identification Number (HIN) should start with <b>CTY</b> (Catalina Yachts) <b>K</b> (for C-25) then maybe <b>2230</b> (your hull number) <b>M</b> (for the date format) <b>81</b> (your production year if you're #2230) and a letter from <b>A</b> to <b>L</b> (for August through July respectively). That's all it will tell you.
Edited by - Stinkpotter on 04/01/2013 10:12:09
sailboat
Response Posted - 04/01/2013 :  10:44:59  Show Profile
Thanks. I might have to rub a piece of paper with a pencil to get the number. Thanks again, Mike
ftworthsailor
Response Posted - 04/17/2014 :  13:18:52  Show Profile  Visit ftworthsailor's Homepage
Is there another location for this HIN? It looks like mine has either been completely covered or removed. I am going to sand the gelcoat down to the fiberclass in this area to see if I can uncover the serial number. Yikes!! They wont allow me to register it without a picture or a pencil scratching of the number.
Response Posted - 04/17/2014 :  14:06:01  Show Profile
Stop!! Sanding will only remove any chance of finding it. The fiberglass was laid up on the gelcoat in the mold, and the HIN was etched into the gelcoat by hand after the hull came out of the mold. It should be just below the rub-rail on the starboard side of the transom, and can be very hard to see.
With your hull number, Catalina should be able to give you a letter certifying the full HIN. Then I suppose you could scratch it in yourself with a hot nail... (?)
Edited by - Stinkpotter on 04/17/2014 14:08:43
