 Hatch gasket repair
Tomas Kruska
Czech Republic
Initially Posted - 09/25/2011 :  11:57:09  Show Profile  Visit Tomas Kruska's Homepage
This weekend I was replacing the old forward hatch and the pop-top gasket.
I've ordered this white EVA foam gasket from CD http://www.catalinadirect.com/index.cfm?fuseaction=product.display& product_ID=1307 but I have to say its completly useless. Its too much high density so the forward hatch is unable to close. And even if closed, it does not seal as it should. What a waste of money
So I ordered localy and relatively cheap the EPDM rubber D profile used for industry sealing.
- 21x17 mm with self adhesive side.
Then I just semi-cut the profile to make the corners so It's all in one piece. It nicely adapts and the hatch is easy to close.
Here is the picture of the forward hatch
This hatch with the pop-top is water tight again.
PS: The longest part was to get out all that old junk. Uff.
Dalpol Phobos 21, 2013, Sole Mio, hull #27, current adventures - We sail Phobos 21
PO of Catalina C25, 1978, High Anxiety, hull #701, SR, FK, L-dinette, inboard diesel Volvo Penta MD2010C w/saildrive - more info
Edited by - Tomas Kruska on 09/25/2011 11:58:50
Response Posted - 09/25/2011 :  12:01:58  Show Profile  Visit delliottg's Homepage
Nice clean install!
Response Posted - 09/25/2011 :  17:49:51  Show Profile
I'm glad you posted. I was thinking of replacing my gaskets too. I'll go for a softer, locally acquired material for my forward hatch, or maybe for both.
Tomas Kruska
Czech Republic
Response Posted - 09/26/2011 :  03:48:09  Show Profile  Visit Tomas Kruska's Homepage
Dave, I suppose you have the model with molded groove for gasket?
Response Posted - 09/26/2011 :  06:38:23  Show Profile  Visit DaveR's Homepage
Very nice job Thomas ..... as usual!
NCBrew
Response Posted - 09/26/2011 :  13:01:27  Show Profile
<br />This weekend I was replacing the old forward hatch and the pop-top gasket.
I wish I had seen your post before I spent $38.00 at CD. I put it in but can hardly close the hatch. We will see it it is leakproof
Response Posted - 09/26/2011 :  14:01:59  Show Profile
Yes I do Tomas, but I don't think it will be a problem.
Response Posted - 09/27/2011 :  04:11:51  Show Profile
&lt;&lt; white EVA foam gasket from CD &gt;&gt;
I thought the gasket material was designed for the poptop. Fits in the poptop gasket gutter and dense enough to conform to the weight.
Not designed for the hatch gasket, as you found, it is too thick for that application.
Edited by - redeye on 09/27/2011 04:12:25
froell56
Response Posted - 09/27/2011 :  15:27:33  Show Profile
So, where did you get the D profile gasket material? Home supply store? Hardware store?
Tomas Kruska
Czech Republic
Response Posted - 09/29/2011 :  00:53:05  Show Profile  Visit Tomas Kruska's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by froell56</i>
<br />So, where did you get the D profile gasket material? Home supply store? Hardware store?
Just googled and found local manufacturer of window's gaskets. I bet you will find the same in US.
Mine is from this kind of rubber http://en.wikipedia.org/wiki/EPDM_rubber.
